Aller au contenu principal
Likebook Muses Rear Cover Replacement
Ce dont vous avez besoin
  1. Likebook Muses Rear Cover Replacement, Power off: étape 1, image 1 de 1
    • Power off the tablet by holding down the power button (on the bottom) and tapping "Power off" on screen, then wait 10-15 seconds for the underlying Android system to shut down.
  2. Likebook Muses Rear Cover Replacement, Rear Cover: étape 2, image 1 de 1
    • Unscrew the two Torx T2 screws surrounding the USB port.
    • Image needed: showing just the bottom in order to highlight screws in blue
  3. Likebook Muses Rear Cover Replacement: étape 3, image 1 de 3 Likebook Muses Rear Cover Replacement: étape 3, image 2 de 3 Likebook Muses Rear Cover Replacement: étape 3, image 3 de 3
    • Use the opening tool to pry at the lip in between the bezel and rear cover,
    • then slide in your opening pick with the flat end,
    • and slide it around to undo these clips.
  4. Likebook Muses Rear Cover Replacement: étape 4, image 1 de 3 Likebook Muses Rear Cover Replacement: étape 4, image 2 de 3 Likebook Muses Rear Cover Replacement: étape 4, image 3 de 3
    • (Note to self: Try opening the side using opening tools)
    • After releasing the clips, lift the front bezel out.
    • The extension piece for the power button can fall out. Don't lose this!
  5. Likebook Muses Rear Cover Replacement: étape 5, image 1 de 1
    • The rear cover has been removed.
Kevin Bhasi
Membre depuis le 12/26/14
1 262 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 125
