Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
For any major replacement, you need to disassemble the router to get full access to the motherboard
  1. Remove the antennas by unscrewing them from the base. Flip over the device and locate the four rubber feet on the bottom. Remove the rubber feet with tweezers
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Use a blue plastic opening tool to remove the top cover.
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  5. Gently lift the motherboard and remove it from the case Put the motherboard over a (preferably white) surface. Put the motherboard over a (preferably white) surface.
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
Denis
Membre depuis le 15/09/2016
560 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 11-1, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 86
