Introduction
Faulty power ports can result in loss of power to your device. This guide will show you how to identify and replace a dysfunctional power port on your router.
Make sure you are in a well ventilated area at room temperature with the proper safety equipment when soldering.
Ce dont vous avez besoin
Remove the antennas by unscrewing them from the base.
Flip over the device and locate the four rubber feet on the bottom.
Remove the rubber feet with tweezers
Locate the power port on both sides of the motherboard.
The power port on the top side is in a rectangular black casing.
Identify the three prongs where the power port is soldered to on the reverse side.
Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
Use a black spudger to gently separate the power port from the motherboard
2 autres ont terminé cette réparation.
