Introduction
You will start by isolating the motherboard and then continue to make the suggested repairs by soldering.
Ce dont vous avez besoin
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Remplacement des antennes du Linksys WAP54g
Unscrew the two screws that connect the motherboard to the bottom casing.
Using a soldering iron, desolder the LED lights from the bottom of the logic board.
For help with soldering or desoldering refer to ifixit's soldering guide: Comment souder et dessouder des connexions
Once the soldering is complete, the device should work and the LED lights should light up.
