Introduction
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
Ce dont vous avez besoin
To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
Pull the top piece upwards and away from the bottom to remove.
Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (Comment souder et dessouder des connexions).
Desolder each pin using the iFixit Soldering Guide (Comment souder et dessouder des connexions). Gently remove functional component for replacement.
