Aller au contenu principal
Linsay Model F-7HD2CORE Screen Replacement
Ce dont vous avez besoin
  1. Linsay Model F-7HD2CORE Screen Replacement, Screen: étape 1, image 1 de 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: étape 1, image 2 de 3 Linsay Model F-7HD2CORE Screen Replacement, Screen: étape 1, image 3 de 3
    • Insert your plastic opening tool in between the black and white portions of your device.
    • Gently pry the top screen from the base of the tablet.
    • Your tablet should now look like the third photo.
  2. Linsay Model F-7HD2CORE Screen Replacement: étape 2, image 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: étape 2, image 2 de 2
    • Peel the microphone from the back of the device.
  3. Linsay Model F-7HD2CORE Screen Replacement: étape 3, image 1 de 1
    • Remove the tape from the indicated copper strip.
  4. Linsay Model F-7HD2CORE Screen Replacement: étape 4, image 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: étape 4, image 2 de 2
    • Use your 00 phillips head screwdriver to remove the three 4mm phillips screws circled in red.
  5. Linsay Model F-7HD2CORE Screen Replacement: étape 5, image 1 de 1
    • Remove the soldered portion of the circuit board on the screen.
    • You will need a soldering kit to reattach this part.
  6. Linsay Model F-7HD2CORE Screen Replacement: étape 6, image 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: étape 6, image 2 de 2
    • Use the blunt end of the spudger to remove the circuit panel and battery from the glass screen portion of the device.
    • There will be several small hooks holding the screen onto the back panel.
  7. Linsay Model F-7HD2CORE Screen Replacement: étape 7, image 1 de 2 Linsay Model F-7HD2CORE Screen Replacement: étape 7, image 2 de 2
    • Gently pull the two pieces of the tablet apart.
    • Your tablet should now look like image two.
    • You are now ready to attach your new screen!
2 autres ont terminé cette réparation.
Lindsay Byrnes
Membre depuis le 01/28/15
471 Réputation
2 tutoriels rédigés
Équipe
Penn State, Team 1-5, Kaschak Winter 2015 Membre de l'équipe Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 membres
2 tutoriels rédigés
Un commentaire
Excellent work!
Glen Lind - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,314
