Aller au contenu principal
Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement
Ce dont vous avez besoin
  1. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: étape 1, image 1 de 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: étape 2, image 1 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: étape 2, image 2 de 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: étape 2, image 3 de 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: étape 3, image 1 de 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: étape 4, image 1 de 2 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: étape 4, image 2 de 2
    • Unscrew the burnt-out light bulb with a counter-clockwise twist.
    • Do not apply too much pressure when unscrewing light bulb, as the light bulb may break.
Ligne d'arrivée
5 autres ont terminé cette réparation.
Nick Kaprielian
Membre depuis le 01/14/14
525 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 17-3, Forte Winter 2014 Membre de l'équipe Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 membres
7 tutoriels rédigés
4 commentaires
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - Réponse
Saved me a headache. Couldn't figure out how to remove base. Thanks!
mccullough1251 - Réponse
Helpful guide. Thank you.
In case there is any confusion, all you have to do is push in that tab on one side and lift. No twisting necessary. Also, the other side will come off.
jgprus - Réponse
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
Melissa Fleming - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 57
Total : 15,415
