Aller au contenu principal
Logitech Dual Action Joystick Replacement
Ce dont vous avez besoin
  1. Logitech Dual Action Joystick Replacement, Taking out the screws: étape 1, image 1 de 1
    • To get into the controller, you will need to unscrew the 7 screws on the back.
    • You will have to remove the bottom oval sticker to reveal the screw marked with orange.
  2. Logitech Dual Action Joystick Replacement, Opening the controller: étape 2, image 1 de 3 Logitech Dual Action Joystick Replacement, Opening the controller: étape 2, image 2 de 3 Logitech Dual Action Joystick Replacement, Opening the controller: étape 2, image 3 de 3
    • With the screws removed, turn the controller upside down and separate the front end from the back end.
    • It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
    • There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
  3. Logitech Dual Action Joystick Replacement, Replacing the joystick: étape 3, image 1 de 2 Logitech Dual Action Joystick Replacement, Replacing the joystick: étape 3, image 2 de 2
    • With the case off, the joysticks can be removed by pulling them upward.
    • To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
    • Make sure that the cut-out side of the joystick is towards the outsides of the device.
Ligne d'arrivée
14 autres ont terminé cette réparation.
Brian Neuman
Membre depuis le 01/20/15
893 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 7-4, Remmell Winter 2015 Membre de l'équipe USF Tampa, Team 7-4, Remmell Winter 2015
USFT-REMMELL-W15S7G4
4 membres
3 tutoriels rédigés
5 commentaires
Can the Analogue Stick be replaced with the One of XBOX 360 or PS3 Controller
shivam sah - Réponse
will the buttons still work if you put it all back?
Atsuku - Réponse
When you press the buttons, they don't work, but when you press hard, they only work, and they don't work just by pressing normally?
[deleted] - Réponse
Merci pour le site.excusez moi pour le dérangement j'ai ma manette PS2 qui ne fonctionne pas quand je branche ça me dit que c'est pas connecté
Mohamed Abass Sylla - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 163
Total : 9,837
