Aller au contenu principal
Logitech Extreme 3D Pro Disassembly of the handle
Ce dont vous avez besoin
  1. Logitech Extreme 3D Pro Disassembly of the handle, Disassembly of the handle: étape 1, image 1 de 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Disassembly of the handle: étape 2, image 1 de 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Disassembly of the handle: étape 3, image 1 de 2 Logitech Extreme 3D Pro Disassembly of the handle: étape 3, image 2 de 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
6 autres ont terminé cette réparation.
Emanuel Canela
Membre depuis le 01/25/18
1 297 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 membres
7 tutoriels rédigés
2 commentaires
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
erock steady - Réponse
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
cody Werdal -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 34
Total : 3,463
