Introduction
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the top handle portion of the joystick.
Ce dont vous avez besoin
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
6 autres ont terminé cette réparation.
2 commentaires
yeah but i got this far before looking at the site, and what i really want to see is how the cotter ring pin is set on the shaft that enables the z-rot instead of locking it down.
if you havent worked it out already, the Z-rot spring needs spread across a little 3/8 inch tab, otherwise it will lock the axis a few degrees off center
