Aller au contenu principal
Introduction
After a long use the joystick trigger might experience a lack of strength within the trigger's internal spring.
Pièces
Aucune pièce spécifiée.
  1. Remove these three Phillips #1 screws:
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Pull apart the joystick chassis by hand. Release this clip located underneath the  hand rest
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  5. Remove the plastic trigger from the joystick.
    • Remove the plastic trigger from the joystick.
Emanuel Canela
Membre depuis le 25/01/2018
800 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 199
