Aller au contenu principal
Logitech Extreme 3D Pro Top button circuit board Replacement
Ce dont vous avez besoin
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: étape 1, image 1 de 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: étape 2, image 1 de 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: étape 3, image 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: étape 3, image 2 de 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: étape 4, image 1 de 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: étape 4, image 2 de 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: étape 4, image 3 de 3
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: étape 5, image 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: étape 5, image 2 de 2
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: étape 6, image 1 de 2 Logitech Extreme 3D Pro Top button circuit board Replacement: étape 6, image 2 de 2
    • Disconnect the smaller cable from the button board.
4 autres ont terminé cette réparation.
Emanuel Canela
Membre depuis le 01/25/18
1 297 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team S7-G1, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 27
Total : 2,079
