Introduction
Replacing the battery for the Logitech G Cloud is simple and can be accomplished in four steps. You will need a wedge tool and a Phillips #00 screwdriver. Avoid of using metal tools when removing the battery; instead, use the spudger as listed in the tool section. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the interior plating.
For your safety, turn on your G Cloud and allow the battery to fully discharge before starting this procedure. A charged lithium-ion polymer battery can be very dangerous if accidentally punctured. Heating a charged battery is a fire hazard. If your battery looks puffy or swollen, take extra precautions.
Ce dont vous avez besoin
Power the device off and turn it over so the screen is face down.
Insert an opening pick into the seam between the back plate and left handguard.
Pry around the entire perimeter until the handguard fully releases.
Remove the handguard.
Repeat the previous three bullets on the right handguard.
Outil utilisé dans cette étape :Tesa 61395 Tape$5.99
Insert the flat end of a spudger under the edge of the battery press connector and lift straight up to disconnect it.
Insert an opening tool under the bottom edge of the battery. Gently and slowly lift straight up to separate the adhesive on the battery from the console.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
