Introduction
Replacing the case for the Logitech G Cloud is simple and can be accomplished in three steps. You will need a wedge tool and a Phillips #00 screwdriver. Carefully read the instructions before starting to disassemble the Logitech G Cloud. You may hear loud popping noises when you remove the casing.
Ce dont vous avez besoin
Power the device off and turn it over so the screen is face down.
Insert an opening pick into the seam between the back plate and left handguard.
Pry around the entire perimeter until the handguard fully releases.
Remove the handguard.
Repeat the previous three bullets on the right handguard.
