Aller au contenu principal
Logitech G Cloud Right Joystick Replacement
Ce dont vous avez besoin
  1. Logitech G Cloud Right Joystick Replacement, Case: étape 1, image 1 de 2 Logitech G Cloud Right Joystick Replacement, Case: étape 1, image 2 de 2
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
  2. Logitech G Cloud Right Joystick Replacement: étape 2, image 1 de 1
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
  3. Logitech G Cloud Right Joystick Replacement: étape 3, image 1 de 2 Logitech G Cloud Right Joystick Replacement: étape 3, image 2 de 2
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
  4. Logitech G Cloud Right Joystick Replacement: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
  5. Logitech G Cloud Right Joystick Replacement: étape 5, image 1 de 2 Logitech G Cloud Right Joystick Replacement: étape 5, image 2 de 2
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
  6. Logitech G Cloud Right Joystick Replacement, Right Joystick: étape 6, image 1 de 3 Logitech G Cloud Right Joystick Replacement, Right Joystick: étape 6, image 2 de 3 Logitech G Cloud Right Joystick Replacement, Right Joystick: étape 6, image 3 de 3
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the R2 trigger sensor from the joystick plate; it should stay attached to the console.
  7. Logitech G Cloud Right Joystick Replacement: étape 7, image 1 de 2 Logitech G Cloud Right Joystick Replacement: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Spencer Davis
Membre depuis le 01/23/25
517 Réputation
6 tutoriels rédigés
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 41
Total : 241
