Aller au contenu principal
Logitech G27 C-Clamp Replacement
Ce dont vous avez besoin
  1. Logitech G27 C-Clamp  Replacement, Steering Wheel: étape 1, image 1 de 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
  2. Logitech G27 C-Clamp  Replacement: étape 2, image 1 de 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
  3. Logitech G27 C-Clamp  Replacement: étape 3, image 1 de 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
  4. Logitech G27 C-Clamp  Replacement: étape 4, image 1 de 1
    • Carefully remove the PCB board from the wheel hub.
  5. Logitech G27 C-Clamp  Replacement: étape 5, image 1 de 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
  6. Logitech G27 C-Clamp  Replacement: étape 6, image 1 de 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
  7. Logitech G27 C-Clamp  Replacement: étape 7, image 1 de 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
  8. Logitech G27 C-Clamp  Replacement: étape 8, image 1 de 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
  9. Logitech G27 C-Clamp  Replacement: étape 9, image 1 de 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
  10. Logitech G27 C-Clamp  Replacement: étape 10, image 1 de 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
  11. Logitech G27 C-Clamp  Replacement: étape 11, image 1 de 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
  12. Logitech G27 C-Clamp  Replacement: étape 12, image 1 de 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
  13. Logitech G27 C-Clamp  Replacement: étape 13, image 1 de 2 Logitech G27 C-Clamp  Replacement: étape 13, image 2 de 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
  14. Logitech G27 C-Clamp  Replacement, C-Clamp: étape 14, image 1 de 1
    • Unscrew the piece holding the C-Clamp in place with your hand.
  15. Logitech G27 C-Clamp  Replacement: étape 15, image 1 de 2 Logitech G27 C-Clamp  Replacement: étape 15, image 2 de 2
    • Push the remaining nob forward and then inward through the slot.
  16. Logitech G27 C-Clamp  Replacement: étape 16, image 1 de 2 Logitech G27 C-Clamp  Replacement: étape 16, image 2 de 2
    • The C-Clamp can now be easily pulled out of the bottom of the device.
23 autres ont terminé cette réparation.
Daniel Louis
Membre depuis le 04/28/15
718 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-4, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 membres
25 tutoriels rédigés
14 commentaires
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Mumin Mazhar - Réponse
Look for it at eBay.
Eduardo -
I also need to find a place to buy replacement C-clamps from
hockeyjockone - Réponse
Can you tell me where I can buy these clamps?
kholiwen - Réponse
step 9 to 13 not needed ... please confirm
Matt Na - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 65
30 derniers jours : 210
Total : 45,292
