Introduction
This guide will explain how to remove the share/options/PS buttons from the Logitech G29 wheel. If these buttons are malfunctioning, this guide will explain how to remove them and replace them without getting rid of the whole wheel. This process is not hard and can be completed with ease.
Ce dont vous avez besoin
Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
Remove Daughterboard using bit J0
Remove the 2 small black screws diameter 3.41mmlength 5mm from the small PCB using the J00 bit. Once the small PCB is unscrewed set the whole board aside. This will expose a black housing that all three buttons are attached to. This was removed using the same bit and screws of the same diameter.
