Aller au contenu principal
Logitech G29 Driving Force Share/Options/PS Buttons Replacement
Ce dont vous avez besoin
  1. Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: étape 1, image 1 de 3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: étape 1, image 2 de 3 Logitech G29 Driving Force Share/Options/PS Buttons Replacement, Share/Options/PS Buttons: étape 1, image 3 de 3
    • Take off the 6 black hex screws holding the Playstation center cap using the H 4.0 bit. The outer diameter of these screws are 8.40mm with a length of 26mm.
    • Once the center cap is off, take the face of the wheel off the stand. Before totally taking off, disconnect the 7 pin white cable running into the base of the wheel and place base aside.
  2. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: étape 2, image 1 de 1
    • Take off the 7 4.32mm diameter 8mm long silver screws holding the PCB to the black housing on the wheel using bit J0.
  3. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: étape 3, image 1 de 1
    • Remove Daughterboard using bit J0
    • Remove the 2 small black screws diameter 3.41mmlength 5mm from the small PCB using the J00 bit. Once the small PCB is unscrewed set the whole board aside. This will expose a black housing that all three buttons are attached to. This was removed using the same bit and screws of the same diameter.
  4. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: étape 4, image 1 de 1
    • A black housing that all three buttons are attached to will be seen. This was removed using the same bit and screws of the same diameter.
  5. Logitech G29 Driving Force Share/Options/PS Buttons Replacement: étape 5, image 1 de 1
    • Pick up black housing using fingers (universal size) and remove.
Ben varner
Membre depuis le 11/08/23
373 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team 1-3, Harley Fall 2023 Membre de l'équipe IUPUI, Team 1-3, Harley Fall 2023
IUPUI-HARLEY-F23S1G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 28
Total : 326
