Aller au contenu principal
Logitech G29 Steering Wheel Motherboard Replacement
Ce dont vous avez besoin
  1. Logitech G29 Steering Wheel Motherboard Replacement, Steering Wheel Motherboard: étape 1, image 1 de 1
    • Remove the six 32mm long 4mm Allen screws from the faceplate of the steering wheel
  2. Logitech G29 Steering Wheel Motherboard Replacement: étape 2, image 1 de 1
    • Remove the six 10mm long #00 Phillips head screws from the back of the steering wheel. Rotate the steering wheel 60 degrees per screw until all 6 screws are removed.
    • Gently lift the steering wheel off the steering column
  3. Logitech G29 Steering Wheel Motherboard Replacement: étape 3, image 1 de 1
    • Gently unplug the wiring harness from the circuit board.
  4. Logitech G29 Steering Wheel Motherboard Replacement: étape 4, image 1 de 1
    • Remove the 6 10mm long #00 Philips head screws that hold the circuit board to the steering wheel.
  5. Logitech G29 Steering Wheel Motherboard Replacement: étape 5, image 1 de 1
    • Remove the two 8mm long #00 Philips head screws holding the smaller circuit board onto the steering wheel.
  6. Logitech G29 Steering Wheel Motherboard Replacement: étape 6, image 1 de 1
    • Gently lift the circuit board off the steering wheel. replace the circuit board with the new part.
  7. Logitech G29 Steering Wheel Motherboard Replacement: étape 7, image 1 de 1
    • The replacement part should match this image. All buttons on the steering wheel are included on this circuit board.
2 autres ont terminé cette réparation.
Cray McCall
Membre depuis le 09/16/22
193 Réputation
1 tutoriel rédigé
Équipe
2 commentaires
Thx I was an idiot that forgot to check that the switch was out of the way, hence why I needed to replace, so I don't really need instructions as of how to do it, and a recommendation: add that you should make where when reassembling you check that the switch matches up with the switch extension thing so everyone doesn't make my dumb mistake. I would not be here writing this message if I had made sure that switch was there on the second go around (I forgot to put the plastic protector on the metal stand mounts for attaching to a metal cockpit stand) so I found it oddly difficult to put the board back then snap... awkward silence plug in the wheel and it spins around, and mashes every single button, and repeats for hours until I unplug it defeated. All this from a dumb switch. Hope you enjoyed my whole life story... It actually kinda feels like my whole life story lol.
CHUCK SANNEL - Réponse
Hi,
I have a question, we replaced the regular wheel for an F1 mod wheel and since then it hasn't been working optimally the button with the circle doesn't work in game and in the menu it does again, do you guys have any idea what it could be ?
Tommy Edinger - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 110
30 derniers jours : 415
Total : 8,492
