Aller au contenu principal
Logitech G502 Proteus Core Cable Replacement
Ce dont vous avez besoin
  1. Logitech G502 Proteus Core Cable Replacement, Cable: étape 1, image 1 de 2 Logitech G502 Proteus Core Cable Replacement, Cable: étape 1, image 2 de 2
    • Use a hairdryer to heat three mouse feet briefly.
    • Each mouse foot should take 7-8 seconds to heat up.
  2. Logitech G502 Proteus Core Cable Replacement: étape 2, image 1 de 3 Logitech G502 Proteus Core Cable Replacement: étape 2, image 2 de 3 Logitech G502 Proteus Core Cable Replacement: étape 2, image 3 de 3
    • Remove the mouse feet gently.
    • Avoid bending the mouse feet.
  3. Logitech G502 Proteus Core Cable Replacement: étape 3, image 1 de 2 Logitech G502 Proteus Core Cable Replacement: étape 3, image 2 de 2
    • Use a screwdriver to remove the four 12.5 mm screws.
  4. Logitech G502 Proteus Core Cable Replacement: étape 4, image 1 de 3 Logitech G502 Proteus Core Cable Replacement: étape 4, image 2 de 3 Logitech G502 Proteus Core Cable Replacement: étape 4, image 3 de 3
    • Use a spudger to pry open the bottom case.
    • A screwdriver is shown in the photo but screwdrivers shouldn't be used for prying. They might accidentally damage internal components with a slip.
  5. Logitech G502 Proteus Core Cable Replacement: étape 5, image 1 de 2 Logitech G502 Proteus Core Cable Replacement: étape 5, image 2 de 2
    • Raise the tabs to disconnect the ribbon.
  6. Logitech G502 Proteus Core Cable Replacement: étape 6, image 1 de 2 Logitech G502 Proteus Core Cable Replacement: étape 6, image 2 de 2
    • Pull out the pin and remove the scroll wheel assembly.
    • Take out the two springs under the scroll wheel assembly.
    • Be careful when lifting the scroll wheel assembly. Do not lose the two specified springs.
  7. Logitech G502 Proteus Core Cable Replacement: étape 7, image 1 de 1
    • Unscrew five 12.5mm screws from the motherboard.
  8. Logitech G502 Proteus Core Cable Replacement: étape 8, image 1 de 3 Logitech G502 Proteus Core Cable Replacement: étape 8, image 2 de 3 Logitech G502 Proteus Core Cable Replacement: étape 8, image 3 de 3
    • Open the tabs lock on each side so you can disconnect the ribbon.
    • Disconnect the PCB from the mouse cable.
  9. Logitech G502 Proteus Core Cable Replacement: étape 9, image 1 de 3 Logitech G502 Proteus Core Cable Replacement: étape 9, image 2 de 3 Logitech G502 Proteus Core Cable Replacement: étape 9, image 3 de 3
    • Pull out the plastic piece.
    • Remove the mouse cable.
7 autres ont terminé cette réparation.
Sen
Membre depuis le 09/19/21
358 Réputation
1 tutoriel rédigé
Équipe
York University, Team E-13, Melo-Thaiss Fall 2021 Membre de l'équipe York University, Team E-13, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG13
1 membre
2 tutoriels rédigés
2 commentaires
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
Black.Technician - Réponse
If you are careful enough, you don't need to remove the side button ribbon.
Yueh Tse Chen - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 64
30 derniers jours : 299
Total : 6,978
