Ce dont vous avez besoin
If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
6 autres ont terminé cette réparation.
4 commentaires
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
It's hard to tell, but in the pictures above, it appears that the wires may be soldered to the board and then additionally secured with hot glue.
