Aller au contenu principal
Introduction
A guide on how to replace the left and right switches on a Logitech G700s mouse.
  1. Remove the batteries from the mouse.
    • Remove the batteries from the mouse.
    • Use a plastic opening tool to peel up the four mouse feet.
  2. Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet. Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
    • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
  3. Pull the top of the mouse off of the bottom half. There's a wire connecting the two halves.
    • Pull the top of the mouse off of the bottom half.
    • There's a wire connecting the two halves.
    • Unplug the programmable buttons from the motherboard.
  4. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  5. Remove the black pin that holds the scroll wheel to the motherboard.
    • Remove the black pin that holds the scroll wheel to the motherboard.
  6. Lift the scroll wheel straight up off the motherboard. Be careful not to lose the two small springs! They are magnetic and could attach to any magnetic tip screw driver!
    • Lift the scroll wheel straight up off the motherboard.
    • Be careful not to lose the two small springs! They are magnetic and could attach to any magnetic tip screw driver!
  7. Remove the small black pin and two Phillips #00  screws to free up the scroll wheel. Next, remove the plastic mount that holds the scroll wheel in place.
    • Remove the small black pin and two Phillips #00 screws to free up the scroll wheel.
    • Next, remove the plastic mount that holds the scroll wheel in place.
  8. Remove the two small springs and two Phillips #00 screws from the motherboard. Remove the two small springs and two Phillips #00 screws from the motherboard. Remove the two small springs and two Phillips #00 screws from the motherboard.
    • Remove the two small springs and two Phillips #00 screws from the motherboard.
  9. Desolder the switches from the circuit board and remove them. Desolder the switches from the circuit board and remove them.
    • Desolder the switches from the circuit board and remove them.
2 autre(s) ont terminé cette réparation.
Chase Tisinger
Membre depuis le 14/02/2018
600 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S2-G3, Nance Spring 2018 Membre de l'équipe USF Tampa, Team S2-G3, Nance Spring 2018
USFT-NANCE-S18S2G3
4 membres
5 tutoriels rédigés
Please note, the top PCB can only be removed by desoldering the connections to the lower PCB. Otherwise you risk breaking the top PCB itself, as can be seen in Step 6. Which is far from ideal in restoring this mouse to working order.
Youri - Réponse
lol, you broke the PCB and kept it covered with your thumb all the time as if you don’t need to desolder 14 pins before step 6…
juliusukanis - Réponse
What Youri said. Plus be warned de-soldering the pins is extremely difficult to do without the proper tools, or you risk ripping the copper solder pads of the upper board when doing so (sadly that happened to me). I’d suggest trying solder wick rather than a solder sucker as its a fiddly job.
You are also going to need some fine soldering skills when replacing the board.
Peter Wise - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 7
7 derniers jours : 21
30 derniers jours : 128
Total : 1,268
