Introduction
If you can no longer charge your Logitech G733 headset and you've ruled out a faulty battery, the charging port may need to be replaced. Accessing the power button requires taking off the circuit board, you can also access many other components with these same steps. For this guide, you will need a Phillips #000 screwdriver, a T4 Torx screwdriver, and a soldering iron. This is a difficult replacement. Soldering experience is advised.
Ce dont vous avez besoin
Gently begin to pull the left ear pad off, starting from the top.
Slide your finger around the edges until it releases entirely.
3 autres ont terminé cette réparation.
3 commentaires de tutoriel
Where did you get the spare USB Port from?
The closest match is TE Connectivity 2338792-1 USB TYPE C 3.1 CONN REV TOP MOUNT CH1.6
2338792-1 has diffrient similar casing but diffrient pin configuration and also less pins (12), should have 14 pins. Just contacted Logitech support but they didn't want to tell me the part number. If anyone knows how to get that port, please let us know.
