Aller au contenu principal
Logitech G733 Volume Scroll Wheel Replacement
Ce dont vous avez besoin
  1. Logitech G733 Volume Scroll Wheel Replacement, Volume Scroll Wheel: étape 1, image 1 de 1
    • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Gently pull the left ear pad off, starting from the top.
    • Slide your finger around the edges until it releases completely.
  2. Logitech G733 Volume Scroll Wheel Replacement: étape 2, image 1 de 2 Logitech G733 Volume Scroll Wheel Replacement: étape 2, image 2 de 2
    • Remove the four screws securing the speaker housing using the T4 Torx screwdriver.
    • Place these screws on the magnetic project mat so you don't lose them.
  3. Logitech G733 Volume Scroll Wheel Replacement: étape 3, image 1 de 3 Logitech G733 Volume Scroll Wheel Replacement: étape 3, image 2 de 3 Logitech G733 Volume Scroll Wheel Replacement: étape 3, image 3 de 3
    • The plastic cover should be lose now and you should be able to pull it back to reveal the circuit board inside.
    • Unscrew the screw on the bottom right-hand side of the headphone using the #000 Phillips Screwdriver.
    • Finally, use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
    • The scroll wheel may fly out when you pop the circuit board out.
  4. Logitech G733 Volume Scroll Wheel Replacement: étape 4, image 1 de 2 Logitech G733 Volume Scroll Wheel Replacement: étape 4, image 2 de 2
    • Pull the volume wheel directly out.
    • Place the new scroll wheel in by lining up the two flat surfaces on the connectors.
Antonio Jensen
Membre depuis le 02/14/23
676 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 40
30 derniers jours : 185
Total : 2,124
