Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech Gamepad F310 Buttons Replacement
Ce dont vous avez besoin
  1. Logitech Gamepad F310 Buttons Replacement, Case: étape 1, image 1 de 2 Logitech Gamepad F310 Buttons Replacement, Case: étape 1, image 2 de 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    Demander à FixBot
    Ajouter un commentaire
  2. Logitech Gamepad F310 Buttons Replacement: étape 2, image 1 de 2 Logitech Gamepad F310 Buttons Replacement: étape 2, image 2 de 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    Demander à FixBot
  3. Logitech Gamepad F310 Buttons Replacement: étape 3, image 1 de 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    Demander à FixBot
  4. Logitech Gamepad F310 Buttons Replacement, Buttons: étape 4, image 1 de 2 Logitech Gamepad F310 Buttons Replacement, Buttons: étape 4, image 2 de 2
    • Remove any buttons that need replacement.
    • The buttons sit loosely in the front of the controller, so flipping the front over will drop all of the buttons out.
    Demander à FixBot
You're all finished! To reassemble your device, follow these instructions in reverse order.
Aaron Ajo Joseph
Membre depuis le 02/05/24
73 Réputation
1 tutoriel rédigé
Équipe
1 commentaire de tutoriel
Any idea where I can get the d-pad rubber dome replacement part?
Anggoro Arif Junianto - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 72
Total : 1,399
