Introduction
If your joysticks are cracked, old, or broken, you may want to replace them. Joysticks are key for any game you might play. Follow this guide to replace your joysticks. The joystick are used to move around in games on pc.
No special tools or skills are required.
Ce dont vous avez besoin
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Presque terminé !
You're finished! To reassemble your device, follow these instructions in reverse order.
