Aller au contenu principal
Logitech Harmony 1100 Screen Replacement
Ce dont vous avez besoin
  1. Logitech Harmony 1100 Screen Replacement, How to Open Logitech Harmony 1100: étape 1, image 1 de 2 Logitech Harmony 1100 Screen Replacement, How to Open Logitech Harmony 1100: étape 1, image 2 de 2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. Logitech Harmony 1100 Screen Replacement: étape 2, image 1 de 1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. Logitech Harmony 1100 Screen Replacement: étape 3, image 1 de 2 Logitech Harmony 1100 Screen Replacement: étape 3, image 2 de 2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. Logitech Harmony 1100 Screen Replacement: étape 4, image 1 de 3 Logitech Harmony 1100 Screen Replacement: étape 4, image 2 de 3 Logitech Harmony 1100 Screen Replacement: étape 4, image 3 de 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
  5. Logitech Harmony 1100 Screen Replacement, Screen: étape 5, image 1 de 1
    • Pop out plastic screen backing on front of device.
    • Loosen screen backing by pushing back on plastic clips that are holding the black screen backing in place.
  6. Logitech Harmony 1100 Screen Replacement: étape 6, image 1 de 2 Logitech Harmony 1100 Screen Replacement: étape 6, image 2 de 2
    • Use PH00 Phillips head from the iFixit Tool Kit to remove 3 screws from the circuit on the back half of the device.
    • Flip over the larger circuit board to the left.
    • Use the edge of the circuit board to flip the board over.
    • The connector port in the top right corner may make removal difficult. Lift the logic board above the screw ports, and the connector port should slide out easily.
  7. Logitech Harmony 1100 Screen Replacement: étape 7, image 1 de 2 Logitech Harmony 1100 Screen Replacement: étape 7, image 2 de 2
    • Find the wire that attaches to the screen
    • Push dark grey bar that is used to lock the screen in place, outward from beige bar to disconnect.
    • Remove screen wire
Ligne d'arrivée
3 autres ont terminé cette réparation.
Alex Turissini
Membre depuis le 02/11/16
28 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-5, Burgess Spring 2016 Membre de l'équipe Ohio State, Team 1-5, Burgess Spring 2016
OSU-BURGESS-S16S1G5
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 1,425
