Aller au contenu principal
Logitech Harmony 300 Batteries Replacement
Ce dont vous avez besoin
  1. Logitech Harmony 300 Batteries  Replacement, Identifying the Battery Housing: étape 1, image 1 de 1
    • On the back bottom of the controller, a housing holds the batteries that are used to power the controller.
  2. Logitech Harmony 300 Batteries  Replacement, Removing the Battery Cap: étape 2, image 1 de 1
    • Place a finger on the top of the cap on the indent. While holding the controller with the other hand, press firmly towards the bottom of the controller to loosen the cap.
    • Once the cap is loosen, simply lift the cap out to reveal the batteries.
  3. Logitech Harmony 300 Batteries  Replacement, The Batteries: étape 3, image 1 de 2 Logitech Harmony 300 Batteries  Replacement, The Batteries: étape 3, image 2 de 2
    • Carefully pull the black tap to remove the batteries from the battery housing. When inserting new batteries, be aware of the correct orientation.
Andres Rodriguez
Membre depuis le 10/09/14
137 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-29, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-29, Donnelly Fall 2014
USFT-DONNELLY-F14S1G29
1 membre
1 tutoriel rédigé
5 commentaires
i bought Harmony 350, and it's imposibble to open this cover, I tried to open this cover for few hours wihout luck, my fingers hurt. Return this crap to shop, I have also Harmony 700 which in it cover open easy.
peter.mac83 - Réponse
This instruction is USELESS the catch is too strong! Note all the other questions about the enclosure.
Errol - Réponse
it’s impossible !!!
Pascal jade - Réponse
I agree with the other comments. I’ll keep trying, but so far after 10 minutes I still can’t get the cover to budge.
Barry Boehm - Réponse
pefI too found the battery cover impossible to remove “by hand”. I used the clear plastic package as a cradle for the device,
then used a flat-blade screwdriver applied to the indent where you are meant to push by hand, and pushed hard at about
about a 45° angle. Finally got it open! I filed off a bit of the hook on the cover latch so hopfully it will be easier next time.
Dave Davy - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 2,289
