Aller au contenu principal
Logitech Harmony 900 Button Pad Replacement
Ce dont vous avez besoin
  1. Logitech Harmony 900 Button Pad Replacement, Battery: étape 1, image 1 de 2 Logitech Harmony 900 Button Pad Replacement, Battery: étape 1, image 2 de 2
    • Press the oval shaped button on the lower back of the remote to release the battery cover.
    • While pressing the button, remove the cover.
  2. Logitech Harmony 900 Button Pad Replacement: étape 2, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 2, image 2 de 2
    • Push the battery in, pull it up, and slide it out.
  3. Logitech Harmony 900 Button Pad Replacement, Motherboard: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
  4. Logitech Harmony 900 Button Pad Replacement: étape 4, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 4, image 2 de 2
    • Locate and unscrew the four 50mm screws using the Philips #0 screwdriver.
  5. Logitech Harmony 900 Button Pad Replacement: étape 5, image 1 de 1
    • Use a credit card to pry the black, plastic, back cover off of the device.
    • You may need to get the process started with a metal prying tool before you start using the credit card.
  6. Logitech Harmony 900 Button Pad Replacement: étape 6, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 6, image 2 de 2
    • Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
  7. Logitech Harmony 900 Button Pad Replacement: étape 7, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 7, image 2 de 2
    • Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
    • Again, you may need to use a metal prying tool to get the separation started.
  8. Logitech Harmony 900 Button Pad Replacement: étape 8, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 8, image 2 de 2
    • When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
    • A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
  9. Logitech Harmony 900 Button Pad Replacement: étape 9, image 1 de 2 Logitech Harmony 900 Button Pad Replacement: étape 9, image 2 de 2
    • Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
  10. Logitech Harmony 900 Button Pad Replacement: étape 10, image 1 de 1
    • Using your hands, carefully separate the motherboard from the rest of the remote.
  11. Logitech Harmony 900 Button Pad Replacement, Button Pad: étape 11, image 1 de 2 Logitech Harmony 900 Button Pad Replacement, Button Pad: étape 11, image 2 de 2
    • Peel off the button pads from the device frame.
Tyler Hanks
Membre depuis le 09/25/17
442 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S4-G5, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S4G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 10
Total : 841
