Ce dont vous avez besoin
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #0 screwdriver to remove the (3) three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
Outil utilisé dans cette étape :Tweezers$3.99
Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
3 commentaires
How replace A Mitsubishi Remote Control
How replace A Mitsubishi Remote Control ?
Thanks
Air conditioning
