Aller au contenu principal
Logitech Harmony Companion Harmony Hub Motherboard Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: étape 1, image 1 de 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement, Harmony Hub Motherboard: étape 1, image 2 de 2
    • Remove the non-slip rubber pads on the bottom of the Harmony Hub.
  2. Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 2, image 1 de 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 2, image 2 de 2
    • Unscrew the four 6.0 mm Phillips #0 screws.
  3. Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 3, image 1 de 1
    • Insert the metal opening tool in the slit by the sensor.
    • Carefully separate the Harmony Hub cover from the base.
    • The metal opening tool could damage the device, so use with care.
  4. Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 4, image 1 de 2 Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 4, image 2 de 2
    • Unscrew the 2.0 mm Phillips #0 at the bottom right of the motherboard.
    • Unscrew the 4.0 mm Phillips #0 at the top left of the motherboard.
  5. Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 5, image 1 de 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 5, image 2 de 3 Logitech Harmony Companion Harmony Hub Motherboard Replacement: étape 5, image 3 de 3
    • Face the Harmony Hub base so the sensor is facing out.
    • Insert the plastic opening tool behind the motherboard on the gold section, which is to the right of the sensor.
    • Lift until you hear a click.
Cassidy Wardlow
Membre depuis le 09/28/17
689 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 515
