Aller au contenu principal
Logitech Harmony Companion Remote Motherboard Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: étape 1, image 1 de 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: étape 2, image 1 de 1
    • Push the battery cover upward.
  3. Logitech Harmony Companion Remote Motherboard Replacement: étape 3, image 1 de 3 Logitech Harmony Companion Remote Motherboard Replacement: étape 3, image 2 de 3 Logitech Harmony Companion Remote Motherboard Replacement: étape 3, image 3 de 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: étape 4, image 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: étape 4, image 2 de 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: étape 5, image 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: étape 6, image 1 de 2 Logitech Harmony Companion Remote Motherboard Replacement: étape 6, image 2 de 2
    • Use the plastic opening tool to remove the motherboard.
6 autres ont terminé cette réparation.
Cassidy Wardlow
Membre depuis le 09/28/17
716 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 membres
4 tutoriels rédigés
1 commentaire de tutoriel
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 73
Total : 7,325
