Aller au contenu principal
Logitech Harmony Smart Control Battery Contact Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: étape 1, image 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: étape 1, image 2 de 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: étape 2, image 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement: étape 2, image 2 de 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: étape 3, image 1 de 3 Logitech Harmony Smart Control Battery Contact  Replacement: étape 3, image 2 de 3 Logitech Harmony Smart Control Battery Contact  Replacement: étape 3, image 3 de 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: étape 4, image 1 de 2 Logitech Harmony Smart Control Battery Contact  Replacement: étape 4, image 2 de 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: étape 5, image 1 de 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Josh Hendricks
Membre depuis le 09/17/15
464 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 membres
5 tutoriels rédigés
1 commentaire de tutoriel
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 5,132
