Aller au contenu principal
Logitech Harmony Smart Control Charging Port Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: étape 1, image 1 de 2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: étape 1, image 2 de 2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: étape 2, image 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: étape 2, image 2 de 2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: étape 3, image 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: étape 3, image 2 de 2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: étape 4, image 1 de 2 Logitech Harmony Smart Control Charging Port Replacement: étape 4, image 2 de 2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: étape 5, image 1 de 3 Logitech Harmony Smart Control Charging Port Replacement: étape 5, image 2 de 3 Logitech Harmony Smart Control Charging Port Replacement: étape 5, image 3 de 3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: étape 6, image 1 de 3 Logitech Harmony Smart Control Charging Port Replacement: étape 6, image 2 de 3 Logitech Harmony Smart Control Charging Port Replacement: étape 6, image 3 de 3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Josh Hendricks
Membre depuis le 09/17/15
464 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 858
