Aller au contenu principal
Logitech Harmony Smart Control Hub Light Bulb Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: étape 1, image 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement, Light Bulb: étape 1, image 2 de 2
    • Use a spudger to lift up one of the rubber pads on the bottom of the hub.
    • Pull back the rubber pad and remove it. This will expose the screws on the bottom of the device.
    • Repeat for the second rubber pad.
  2. Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 2, image 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 2, image 2 de 2
    • Use a PH00 screwdriver bit to remove the four 6mm Phillips screws on the bottom of the device.
  3. Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 3, image 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 3, image 2 de 2
    • Use a spudger to separate the top and bottom pieces of the device.
  4. Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 4, image 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 4, image 2 de 2
    • Use the PH00 screwdriver bit to unscrew the three 4mm Phillips screws on the control board.
  5. Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 5, image 1 de 2 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 5, image 2 de 2
    • Place the end of the opening tool under the yellow corner of the circuit board as shown.
    • Gently push upward to pry the board from its housing.
  6. Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 6, image 1 de 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 6, image 2 de 3 Logitech Harmony Smart Control Hub Light Bulb Replacement: étape 6, image 3 de 3
    • Determine which of the five bulbs are defective.
    • Turn the board over to expose the bulb solder.
    • Using a soldering iron, remove the solder and bulb. Replace with a new bulb and re-solder.
2 autres ont terminé cette réparation.
Josh Hendricks
Membre depuis le 09/17/15
464 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 651
