Aller au contenu principal
Logitech Harmony Smart Control Reset Button Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: étape 1, image 1 de 2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: étape 1, image 2 de 2
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: étape 2, image 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: étape 2, image 2 de 2
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: étape 3, image 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: étape 3, image 2 de 2
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: étape 4, image 1 de 2 Logitech Harmony Smart Control Reset Button Replacement: étape 4, image 2 de 2
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: étape 5, image 1 de 3 Logitech Harmony Smart Control Reset Button Replacement: étape 5, image 2 de 3 Logitech Harmony Smart Control Reset Button Replacement: étape 5, image 3 de 3
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: étape 6, image 1 de 3 Logitech Harmony Smart Control Reset Button Replacement: étape 6, image 2 de 3 Logitech Harmony Smart Control Reset Button Replacement: étape 6, image 3 de 3
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Zachary Robinson
Membre depuis le 09/17/15
126 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-2, Harley Fall 2015 Membre de l'équipe IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 961
