Ce dont vous avez besoin
Open the latch that accesses the charging port
Remove the black sticker and remove the screw with the indicated screwdriver
Take the plastic opening tool and run it down the side of the remote to pop the case open
Detach the white clamp to partially disconnect the case from the motherboard
5 autres ont terminé cette réparation.
3 commentaires
I got it done. It was not clear from the instructions what was supposed to happen with the small circuit board with the USB connector that is also holding the battery case in place. Turns out you need to remove yet another screw and then carefully work the battery case out from under that circuit board, which remains in place.
I spent quite a while looking for the “white clamp” at the end of step 1, I never found it and don’t think it existed on my remote.
I managed to break one of the red wires connected to the charging contact on the bank case, and then managed to break the other one while trying to fix the first one. Fortunately, I hauled out my trusty soldering iron — probably hadn’t used it in 20 years — and soldered both wires back into place.
The battery is charging now and seems to be working! Thanks for the guide.
Is this battery any different from the Logitech Harmony Ultimate One?
I think the “white clamp” that David is referring to is the “white connector” that the red arrow is pointing to. My battery was not glued in place but was held in place by double adhesive tape. Of course I reused it. Thank you for the guide.
