Aller au contenu principal
Logitech Harmony Touch Motherboard Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Touch Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Logitech Harmony Touch Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Open the latch that accesses the charging port
    • Remove the black sticker and remove the screw with the indicated screwdriver
    • Take the plastic opening tool and run it down the side of the remote to pop the case open
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out
    • Detach the white clamp to partially disconnect the case from the motherboard
  2. Logitech Harmony Touch Motherboard Replacement: étape 2, image 1 de 3 Logitech Harmony Touch Motherboard Replacement: étape 2, image 2 de 3 Logitech Harmony Touch Motherboard Replacement: étape 2, image 3 de 3
    • Peel back thin yellow plastic film and detach the clip found underneath
    • Remove the screws that connect the motherboard to the case with the suggested screwdriver
    • Next, carefully remove the motherboard from the top piece of the case
    • The motherboard is connected to the bottom part of the case
    • You should now be able to access all of the buttons and remove them from the case
Lennox Saliva-Rojas
Membre depuis le 09/25/17
281 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 729
