Introduction
This guide will show you the process to disassemble the device and replace the motherboard.
Ce dont vous avez besoin
Open the latch that accesses the charging port
Remove the black sticker and remove the screw with the indicated screwdriver
Take the plastic opening tool and run it down the side of the remote to pop the case open
Detach the white clamp to partially disconnect the case from the motherboard
Presque terminé !
