Aller au contenu principal
Logitech Harmony Touch Power Adapter Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Touch Power Adapter Replacement, Power Adapter: étape 1, image 1 de 1
    • Open the latch that assesses the charging port.
    • Remove the black sticker and remove the screw with the indicated screwdriver.
  2. Logitech Harmony Touch Power Adapter Replacement: étape 2, image 1 de 2 Logitech Harmony Touch Power Adapter Replacement: étape 2, image 2 de 2
    • Take the plastic opening tool and run it down the side of the remote to pop the case open.
    • While doing this step there are three wires that connect the two pieces, be sure not to rip them out when opening.
    • Detach the white clamp to partially disconnect the case from the motherboard.
  3. Logitech Harmony Touch Power Adapter Replacement: étape 3, image 1 de 1
    • Once your device is open, check to see if wires are intact.
    • If wires are not intact, solder your wires back in place to ensure contact with your charging port.
Jennifer Jimenez
Membre depuis le 09/25/17
198 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S4-G2, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S4-G2, Eyestone Fall 2017
USFT-EYESTONE-F17S4G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 568
