Aller au contenu principal
Logitech Harmony Ultimate Charging Station Motherboard Replacement
Ce dont vous avez besoin
  1. Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: étape 1, image 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: étape 1, image 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement, Charging Station Motherboard: étape 1, image 3 de 3
    • Screws are hidden beneath rubber pads.
    • Peel off the rubber pads.
    • Remove four 6mm screws Phillips #0 screws from the bottom of the device.
  2. Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 2, image 1 de 2 Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 2, image 2 de 2
    • Use the plastic opening tool to remove top shell from device.
  3. Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 3, image 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 3, image 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 3, image 3 de 3
    • Remove the two (4mm) screws using Phillips 1 screwdriver.
  4. Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 4, image 1 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 4, image 2 de 3 Logitech Harmony Ultimate Charging Station Motherboard Replacement: étape 4, image 3 de 3
    • Use the Phillips #0 screwdriver to remove the last (4mm) screw. The motherboard can now be removed.
Lucas Reynolds
Membre depuis le 09/01/15
336 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 8-1, Eyestone Fall 2015 Membre de l'équipe USF Tampa, Team 8-1, Eyestone Fall 2015
USFT-EYESTONE-F15S8G1
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 25
Total : 2,876
