Aller au contenu principal
Logitech K380 Disassembly
Ce dont vous avez besoin
  1. Logitech K380 Disassembly, Prepare for disassembly: étape 1, image 1 de 3 Logitech K380 Disassembly, Prepare for disassembly: étape 1, image 2 de 3 Logitech K380 Disassembly, Prepare for disassembly: étape 1, image 3 de 3
    • Power off the keyboard using the switch on the upper-left corner. You should see a feint red color beneath the swtich.
    • Turn the keyboard over. Pinch the battery compartment at the small finger groove, then lift and remove the battery cover.
    • Remove the two AA batteries by sliding them to the right and pulling them out.
  2. Logitech K380 Disassembly, Remove battery compartment screws: étape 2, image 1 de 2 Logitech K380 Disassembly, Remove battery compartment screws: étape 2, image 2 de 2
    • Use a Phillips #0 driver to remove the two black screws that were covered by the battery compartment
  3. Logitech K380 Disassembly, Remove rubber feet: étape 3, image 1 de 1
    • Using an opening tool, pick, the flat end of a spudger, or another plastic prying tool (not metal) to pry under the rubber feet at each corner. Move your tool in a circle around the foot to release all the adhesive.
    • Keep the feet adhesive-side up in a clean place—you should be able to re-adhere the feet multiple times.
  4. Logitech K380 Disassembly, Remove foot screws: étape 4, image 1 de 2 Logitech K380 Disassembly, Remove foot screws: étape 4, image 2 de 2
    • Use a Phillips #0 driver to remove the four screws from underneath each of the rubber feet.
    • Keep the screws from the top and bottom of the keyboard separate and labeled, as they are different sizes.
  5. Logitech K380 Disassembly, Insert picks: étape 5, image 1 de 3 Logitech K380 Disassembly, Insert picks: étape 5, image 2 de 3 Logitech K380 Disassembly, Insert picks: étape 5, image 3 de 3
    • Insert a pick between the bottom cover and the outer frame. It's easier to start near the top, where your pick can sink deeper and provide more leverage.
    • Pull the bottom cover up by prying with your pick. You will hear clicks or pops as clips release; this is normal and non-damaging.
    • Once your first pick is wedged between the cover and case, insert a second pick nearby. Slide it around the perimeter, prying as you go to release more clips.
  6. Logitech K380 Disassembly, Remove back cover: étape 6, image 1 de 2 Logitech K380 Disassembly, Remove back cover: étape 6, image 2 de 2
    • Once you've loosened the bottom cover enough, you can use your fingers to pull off the bottom cover. Try twisting the cover slightly, and pulling on different sections, to release more clips and gain leverage.
    • Remove the back cover and set it aside.
  7. Logitech K380 Disassembly, Inspect and clean: étape 7, image 1 de 1
    • With the bottom cover removed, you can rotate and shake the unit to release liquids or particles, and inspect one side of the logic board for water damage.
    • Do not pull up on the wide, flat ribbon cable connecting the logic board to the key sensors at bottom. You can pull this up once it is disconnected from the logic board.
  8. Logitech K380 Disassembly, Loosen battery connector: étape 8, image 1 de 1
    • Pull the small metal battery connector out of its notch on the left-hand side of the battery compartment.
    • Do not attempt to fully remove the battery connector, as the right side is soldered to the logic board.
  9. Logitech K380 Disassembly, Remove logic board screws: étape 9, image 1 de 1
    • Use a Phillips #0 driver to remove the two screws holding down the logic board, on either side of the cable connector.
  10. Logitech K380 Disassembly, Remove ribbon cable: étape 10, image 1 de 2 Logitech K380 Disassembly, Remove ribbon cable: étape 10, image 2 de 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the ribbon cable's ZIF connector up, toward the top of the keyboard case.
    • Gently slide the ribbon cable straight out of the connector.
  11. Logitech K380 Disassembly, Remove the logic board: étape 11, image 1 de 3 Logitech K380 Disassembly, Remove the logic board: étape 11, image 2 de 3 Logitech K380 Disassembly, Remove the logic board: étape 11, image 3 de 3
    • Gently lift up on the right side of the battery connector to release it from its bracket.
    • Grasp the logic board by its edges and gently raise it up and out of the case.
    • The power switch bracket and LED light prism are fairly loose, but you may need to wiggle the board slightly to raise it up and out from underneath them.
With the logic board removed and the ribbon cable detached, you can now better clean and inspect your Logitech K380. Use isopropyl alcohol and gentle scrubbing tools to clean up any water damage you may find.
15 autres ont terminé cette réparation.
Kevin Purdy
Membre depuis le 04/11/19
4 054 Réputation
5 tutoriels rédigés
3 commentaires
To access the keys and stabilizers I had to make pressure on them from one side (supr/back/enter/upper) to the other (esc/tab/ctrl…). Only them they separate from de frame (jumping some plastic trash dots).
I have reassembled it back and it works and nothing sounds when moving it fast.
ps: sry for my english, not native.
Emilio - Réponse
Was trying to find an easy way to clean pasta sauce from under the faceplate. instructions were good, and like the comment above says the key base is held to the faceplate by like, plastic rivets, which need to be broken to remove the plate. When you open the board they will be all the little black circles. If you try to pry the board off with your fingers some of these will just pop off around the edges (irreversible) which will help you identify what they look like. I had to take a razor blade to some of them to avoid putting too much stress on the faceplate. Breaking these rivets does seem to slightly impact the height of the key faces with respect to the faceplate once it is re-assembled, so I put a paper shim inside (just two narrow strips of regular paper under the HJKL... part of the keyboard) and that seems to have done the trick. Typing on the assembled keyboard now and looks like it works fine.
The bottom part of the keyboard was the hardest to separate, but I was also only using a razorblade and a guitar pick.
Philip - Réponse
The on-off switch was bad! Nothing to do, so the keyboard went to the trash!
Deniz Saral - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 96
30 derniers jours : 365
Total : 16,071
