Ce dont vous avez besoin
There are four screws hidden on the bottom part of the mouse. Two are below the sticker, the last two are below the bottom pads.
Once the scews removed, carefully open the housing. Some cables hold both pieces together
First remove the tricolor battery cable
Then carefully remove the ribbon cable
To remove the battery cover, two more screws need to be removed.
The battery is then held in place with a sticker within the housing.
Remove the three screws (red circles) holding the board in place
Remove the wheel and the white piece of plastic holding it down
A clip (yellow circle) further holds it down
Finally you need to unsolder the charging pads (orange circles)
