Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Logitech UE Boom 3 Battery Replacement
Ce dont vous avez besoin
  1. Logitech UE Boom 3 Battery Replacement, Base: étape 1, image 1 de 2 Logitech UE Boom 3 Battery Replacement, Base: étape 1, image 2 de 2
    • Flip the speaker so the base is facing upwards.
    • Place the iFixit opening picks in the gaps of the speaker.
    • Use the picks to pry open the speaker.
  2. Logitech UE Boom 3 Battery Replacement: étape 2, image 1 de 2 Logitech UE Boom 3 Battery Replacement: étape 2, image 2 de 2
    • Use a Jimmy to completely pry the base away from the rest of the speaker.
  3. Logitech UE Boom 3 Battery Replacement, Battery: étape 3, image 1 de 3 Logitech UE Boom 3 Battery Replacement, Battery: étape 3, image 2 de 3 Logitech UE Boom 3 Battery Replacement, Battery: étape 3, image 3 de 3
    • Remove the adhesive strap holding the battery in place.
    • It is sticky and tightly bounded, but removal is necessary.
    • Pull out the battery by hand until it is out of the casing and being held by the cable only.
  4. Logitech UE Boom 3 Battery Replacement: étape 4, image 1 de 2 Logitech UE Boom 3 Battery Replacement: étape 4, image 2 de 2
    • The battery will still be attached to motherboard via cable.
    • Carefully press down on the lever on the end of the cable and disconnect it from the motherboard.
    • This cable is intricate and is susceptible to damage beyond repair. Be extra careful to precisely insert and remove the cable as bending the pins can result in damage.
    • Remove the battery from the motherboard.
Ethan Donahue
Membre depuis le 03/18/24
600 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-4, Konn Spring 2024 Membre de l'équipe UMass Dartmouth, Team 1-4, Konn Spring 2024
UMASSD-KONN-S24S1G4
4 membres
8 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 15
7 derniers jours : 40
30 derniers jours : 227
Total : 4,840
