Aller au contenu principal
Logitech UE MegaBoom 3 Battery Replacement
Ce dont vous avez besoin
  1. Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: étape 1, image 1 de 2 Logitech UE MegaBoom 3 Battery Replacement, General Disassembly: étape 1, image 2 de 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Battery Replacement: étape 2, image 1 de 3 Logitech UE MegaBoom 3 Battery Replacement: étape 2, image 2 de 3 Logitech UE MegaBoom 3 Battery Replacement: étape 2, image 3 de 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Battery Replacement, Battery: étape 3, image 1 de 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: étape 3, image 2 de 3 Logitech UE MegaBoom 3 Battery Replacement, Battery: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    • Remove the lithium-ion battery from the inside of the speaker by gripping the battery using the plyers.
    • Here, it is ideal to use a tweezers as opposed to the plyers, however, the plyers makes it so much easier to take out the battery.
    • The battery should slide out as you pull against it with the plyers.
    • Remove the battery.
4 autres ont terminé cette réparation.
Jason Doland
Membre depuis le 09/13/23
124 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 1-2, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-2, Sneed Fall 2023
UM-SNEED-F23S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 41
30 derniers jours : 92
Total : 1,493
