Aller au contenu principal
Logitech UE MegaBoom 3 Power Button Control Board Replacement
Ce dont vous avez besoin
  1. Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: étape 1, image 1 de 2 Logitech UE MegaBoom 3 Power Button Control Board Replacement, General Disassembly: étape 1, image 2 de 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 2, image 1 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 2, image 2 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 2, image 3 de 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: étape 3, image 1 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: étape 3, image 2 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement, Power Button Control Board: étape 3, image 3 de 3
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 4, image 1 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 4, image 2 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 4, image 3 de 3
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 5, image 1 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 5, image 2 de 3 Logitech UE MegaBoom 3 Power Button Control Board Replacement: étape 5, image 3 de 3
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
2 autres ont terminé cette réparation.
Anthony Miles
Membre depuis le 09/04/23
1 021 Réputation
6 tutoriels rédigés
Équipe
University of Memphis, Team 1-2, Sneed Fall 2023 Membre de l'équipe University of Memphis, Team 1-2, Sneed Fall 2023
UM-SNEED-F23S1G2
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 27
30 derniers jours : 35
Total : 285
