Aller au contenu principal
Logitech UE MegaBoom Speaker Replacement
Ce dont vous avez besoin
  1. Logitech UE MegaBoom Speaker Replacement, Outer Mesh: étape 1, image 1 de 3 Logitech UE MegaBoom Speaker Replacement, Outer Mesh: étape 1, image 2 de 3 Logitech UE MegaBoom Speaker Replacement, Outer Mesh: étape 1, image 3 de 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Speaker Replacement: étape 2, image 1 de 3 Logitech UE MegaBoom Speaker Replacement: étape 2, image 2 de 3 Logitech UE MegaBoom Speaker Replacement: étape 2, image 3 de 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Speaker Replacement: étape 3, image 1 de 2 Logitech UE MegaBoom Speaker Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Speaker Replacement, Battery: étape 4, image 1 de 1
    • Pull on white strip to remove battery.
    • Remove inner plastic gasket on circuit board.
    • Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
    • Gently pry circuit board up out of recess.
  5. Logitech UE MegaBoom Speaker Replacement, Speaker: étape 7, image 1 de 2 Logitech UE MegaBoom Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Insert a opening tool between the grating and the body of the speaker
    • Pry up allowing the tabs to pop out of place.
    • There will be an audible sound when the tabs have begun to pop out of place.
    • Apply the same procedure to the grating covering the second speaker.
  6. Logitech UE MegaBoom Speaker Replacement: étape 8, image 1 de 2 Logitech UE MegaBoom Speaker Replacement: étape 8, image 2 de 2
    • Use a opening tool to push the thin metal rod located on the side of the speaker out.
    • Using needle nose pliers grasp the rod and pull the rod out of the speaker until fully removed.
    • Remove the remaining three rods.
    • One is located on the same side and two are located on the other speaker.
  7. Logitech UE MegaBoom Speaker Replacement: étape 9, image 1 de 3 Logitech UE MegaBoom Speaker Replacement: étape 9, image 2 de 3 Logitech UE MegaBoom Speaker Replacement: étape 9, image 3 de 3
    • Insert a opening tool between the speaker and the base
    • Pry up allowing the speaker tabs to pop out of place
    • Find and disconnect the wire from the motherboard by pulling in an upward motion.
    • Apply the same procedure to the second speaker.
7 autres ont terminé cette réparation.
Oscar Ambriz
Membre depuis le 09/27/17
962 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S9-G2, Banghart Fall 2017 Membre de l'équipe Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 membres
17 tutoriels rédigés
7 commentaires
Thank you! I was able to glue one of the passive radiators back in place.
Nick Johnston - Réponse
Where can I find a speaker replacement? Thanks for your time
Aldrynaldryn - Réponse
I’ve got the same issue. Where can i find the speaker replacement?
Fred BlacKshadow - Réponse
For those looking for replacement speakers - either directly from Logitech ( $$$ ) or find a broken one on eBay that’s been water logged or some such thing and recover the speakers from that (since they are waterproof speakers)
Thanks for the article - turns out one of my speaker grills had popped loose and was imitating a blown speaker!
Glenn Griffin - Réponse
yes! same issue!
i bought a replacement speaker (which i still have if anyone is looking), but it was a speaker grill stopper that had come unglued and vibrated - sounding exactly as if a blown speaker or radiator.
sweetrobot -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 24
30 derniers jours : 85
Total : 26,944
