Introduction
The snail 510 battery was bought one year ago,I use it every week and it fall down from my desk last week,don't work now.
I don't know which part have problem, have to open it to check.
I find One connecting wire is disconnnected,it seems easy to repair while I don't have related tool. So I have to buy a Soldering tool online, it it easy to deal with the problem with the tool.I believe everyone can deal with it.
Attention:
Be care when use the cute snail,avoid to fall down from high place.
Addition info:
Product from here
Ce dont vous avez besoin
Vidéo d'introduction
It is easy to connect it using the tool,while watch you hand when working.
3 commentaires
How do you take the side cover off? I don't want to ruin it
Same I need to know as well
In the photo from STEP 1 see those 4 holes inside the device?
3 are unoccupied by a screw. These are where three pegs anchor the back face plate.
Pry and shim in these areas with appropriate pry tools and patience. I used a modified razor blade to get it started (thoroughly dull cutting edge, points and corners rounded with flat diamond file and 220 grit sand paper).
