Aller au contenu principal
Lorex A-MPX IR Bullet Camera Disassembly
Ce dont vous avez besoin
  1. Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: étape 1, image 1 de 2 Lorex  A-MPX IR Bullet Camera Disassembly, Quick look: étape 1, image 2 de 2
    • This little camera comes with the LHA4000 kit by Lorex.
    • It has a 4K sensor with motion sensor and infrared lights
  2. Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: étape 2, image 1 de 2 Lorex  A-MPX IR Bullet Camera Disassembly, Removing the lense: étape 2, image 2 de 2
    • Remove the 4 screws holding down the camera lens. They are standard Philipps #1
    • Be careful not to pull the sensor as it is still attached to the signal cables.
  3. Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: étape 3, image 1 de 3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: étape 3, image 2 de 3 Lorex  A-MPX IR Bullet Camera Disassembly, Camera Sensor: étape 3, image 3 de 3
    • The system board is directly attached to the back of the lens.
    • The connector is a simple 4 wires. This make it very easy to repair.
  4. Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: étape 4, image 1 de 3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: étape 4, image 2 de 3 Lorex  A-MPX IR Bullet Camera Disassembly, Outer casing: étape 4, image 3 de 3
    • There is a rubber grommet that keep moisture away from the inside of the board.
    • There IS also this sillica pack inside the camera if moisture ever breach in.
    • The base is fixed to the feet using a single Phillips #1 screw
    • In order to separate the camera from the feet, you will need to undo the connector. The wires are thin so be careful.
  5. Lorex  A-MPX IR Bullet Camera Disassembly, Whole assembly: étape 5, image 1 de 1
    • Very simple design for a very simple device. The whole assembly is held by 6 screws. Making it very easy to re-assemble.
Hans
Membre depuis le 10/20/14
1 920 Réputation
6 tutoriels rédigés
Équipe
Mero IT Services Membre de l'équipe Mero IT Services
Business
1 membre
6 tutoriels rédigés
3 commentaires
Can you do disassembly video on Lorex C861MB camera ?
Mark Curry - Réponse
Can you do a disassembly video on Lorex C861MB camera ?
How much is this camera
Michael Teeter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 29
Total : 2,512
