Introduction
The 1.5v DC motor of the Lorex MC 6950 is to be replaced. This will require taking the camera apart and removing the circuit board from it's LED containment. The motor can be removed directly from the circuit board. To do this, a metal spudger, soldering iron, and a #J0 screwdriver will be needed.
Ce dont vous avez besoin
To remove the motor, you must begin by removing the three screw caps and the 15mm JIS 0 screws associated with them located on the plastic containment shell that the camera is in.
Next, the camera must be removed. A metal spudger will be useful to pry this out as it is sealed inside the outer containment shell.
Once the camera is removed, remove the wires from the outer containment shell.
Be careful. The metal spudger could damage the camera if not handled with care.
